Hello I just installed my 760 today. It plays games just fine. I run 2 screens and while playing Tera Online I notice other monitor has wavey lines on it. Turned V sync on for the game and it decreased how bad it was. I tried other games and this wavey line does not happen. Any idea what would cause this? Any help would be great thanks!
Edit. I have read other forums. So to help knock things off the list I have done the following and the following is set up
-checked all settings with in nivdia control panel.
-monitor is set to 60hz
-Monitor is an acer led(model number not sure as im at work now)
-It is hooked up VGA to dvi adapter to the card.(This worked fine with the 550ti)
-I have moved the monitors apart. I mean each on the other end of desk. Did this for possible interference.
My old 550ti did not do this at all last night. Have been streaming games for last 2 weeks and hand no issue with the games I have played and the other monitor with wavey lines.
Edit
Specs for you as well
i7 2600
Asus MB p8h67-m pro
ASUS GTX760-DC2OC-2GD5 GeForce GTX 760 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
APEVIA ATX-CB700W 700W ATX12V / EPS12V SLI Ready CrossFire Ready Power Supply - OEM
Edit
i7 2600
Asus MB p8h67-m pro
