Single fan or dual fan for the Cooler Master Seidon 120M Liquid Cooling System 120MM Radiator?
I'm getting the Cooler Master Seidon 120M Liquid Cooling System 120MM Radiator which it says it only supports one fan, but it gives me an option to have a dual fan, do i do it?
2 answers Last reply
More about single fan dual fan cooler master seidon 120m liquid cooling system 120mm radiator
  1. You should be able to no problem, I dont see an issue other than trying to mount it to the case once you have 2 fans on it. If you can get it attached to the case 2 fans will work.
    Alright thanks, im going to try it
Cooler Master Fan Dual Components Water Cooling
