Hi, I recently had the following situation:
A couple of nights in a row, my PC shut off overnight, and when I woke up it was off. I didn't think too much of it (maybe power went out or something?), and everything seemed fine. On the third night, I turned the PC on after it was off all day, and it lasted about 15 minutes before shutting off again. I thought it was unlikely to be temperature-related since the PC was cold from being off all day.
Talked to a knowledgeable friend, who suggested replacing the power supply. I was planning to order one and do that, but the next morning I powered up the PC and quickly downloaded HWMonitor. I then watched the CPU temps steadily climb above 90C and then the PC shut off again. So after doing a little research, I decided that what I actually needed to do was replace the cooling.
The PC is a little over 2 years old, from CyberPower. The specs are at the end of the post, but the cooling that came with it was an Asetek LCLC liquid cooling system. From reading a little on forums, it seemed that replacing that with a Cooler Master Hyper 212 was a reasonable thing to do. So I ordered that and some Arctic Silver 5. They arrived today. Using YouTube videos and the instructions, I was able to remove the liquid cooling, replace it with the heat sink and fan combo with no trouble.
Then when I went to test things out, nothing would turn on. No fans, no post, no nothing. I tested all the connections I could find, everything seems okay. There's one small amber LED on the motherboard that turns on when everything is connected and the power supply is on, and I was able to open the CD tray. There is also some kind of power button on the motherboard, and pressing that did nothing either.
Any ideas? Thanks in advance. I include the original system specs below:
BLUETOOTH: None
CAS: Thermaltake V3 Black Mid-Tower Case
CASUPGRADE: None
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CD2: None
CPU: Intel(R) Core™ i7-960 3.20 GHz 8M Intel Smart Cache LGA1366
CS_FAN: Default case fans
FA_HDD: None
FAN: XtremeGear Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA)
FLASHMEDIA: None
FLOPPY: None
GLASSES: None
HDD: 1TB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD (Single Hard Drive)
HDD2: None
IEEE_CARD: None
KEYBOARD: Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard
MB_ADDON: None
MEMORY: 12GB (2GBx6) DDR3/1600MHz Triple Channel Memory Module (Corsair or Major Brand)
MONITOR: None
MONITOR2: None
MONITOR3: None
MOTHERBOARD: (3-Way SLI Support) MSI X58A-GD45 Intel X58 Chipset SLI/CrossFireX Triple-Channel DDR3 ATX Mainboard w/ 7.1 Audio, eSATA, GbLAN, USB3.0, SATA-III, RAID, IEEE1394a, 3 Gen2 PCIe, 3 PCIe X1 & 1 PCI (All Venom OC Certified)
MOUSE: XtremeGear Optical USB 3 Buttons Gaming Mouse
MULTIVIEW: Non-SLI/Non-CrossFireX Mode Supports Multiple Monitors
NCSW: None
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft(R) Windows(R) 7 Home Premium (64-bit Edition)
OVERCLOCK: No Overclocking
POWERSUPPLY: 600 Watts - XtremeGear Power Supply - SLI/CrossFireX Ready
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TEMP: None
TVRC: None
USB: Built-in USB 2.0 Ports
USBFLASH: None
USBHD: None
USBX: None
VC_PHYSX: None
VIDEO: NVIDIA GeForce GTX 460 SE 1GB 16X PCIe Video Card (Major Brand Powered by NVIDIA)
VIDEO2: None
VIDEO3: None
WNC: None
BLUETOOTH: None
CASUPGRADE: None
CD2: None
FA_HDD: None
FLASHMEDIA: None
FLOPPY: None
GLASSES: None
HDD2: None
IEEE_CARD: None
MB_ADDON: None
MONITOR: None
MONITOR2: None
MONITOR3: None
NCSW: None
SPEAKERS: None
TEMP: None
TVRC: None
USBFLASH: None
USBHD: None
USBX: None
VC_PHYSX: None
VIDEO2: None
VIDEO3: None
WNC: None
