Thermaltake Element V Chassis Fans not working
  • Power Supplies
  • Systems
  • Thermaltake
Last response: in Systems
August 28, 2013 6:27:25 AM
Hi,
I have recently had to replace my power supply in my Thermaltake element V PC Chassis, Since doing this the PC boots up fine, the cpu fan is fine but none of the case fans are working, As far as i can see everything is plugged in, has anyone got any suggestions on what i might of missed.
Thanks
More about : thermaltake element chassis fans working
a c 166 ) Power supply
August 28, 2013 1:16:05 PM
Does that case have a fan speed controller on it? If so, are you using the controller or do you have the fans plugged directly into the PSU Molex connector(s)?
