Looking for the best, most silent, most cheaplyiest cooler for Micro ATX build
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112378
is the case and im using a GTX 660 TI twin frozr lll or maybe something else of that size. my RAM is corsair XMS so they are pretty small
haswell socket
any suggestions? budget prob 50 at most ish
1 answer Last reply
More about silent cheaplyiest cooler micro atx build
  1. I can't say for sure, but something like this zalman 92mm cpu cooler should fit in your case. zalman makes some good quality stuff.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
Cooling Build ATX CPUs
