will this water cooler's radiator fit into this case?
  • Overclocking
  • Water Cooling
  • Cases
  • Cooling
August 31, 2013 6:39:32 PM
So I'm planing on buying this case:
http://www.aerocool.com.tw/templarius/chassis/330.html
After seeing that it had little space for an air cooler, I decided I should get this instead: http://www.overclockers.co.uk/showproduct.php?prodid=HS...
My problem is that I don't know if it'll fit properly. Sure, it says it can hold 120mm fans and that's the radiators size, but what about the depth of it?
I've never built a computer before or overclocked and I'm not even really sure I need this for the mediocre overclocking I'm planing on doing. But I've read that good airflow/ cooling is essential and since I live in a hot country (Brazil) I should invest more into it. What do you guys think? Does it make that much of a difference?
Also to those wondering why i chose these 2 items it's because I'm going to buy the pc case in Brazil and the other parts (CPU, GPU, motherboard, monitor and CPU cooler) in England by the end of the year. Additionally I have already bought the RAM (corsair vengance 2x4gb), power supply (corsair cx 600) and HDD (1TB western digital blue).
More about : water cooler radiator fit case
a b K Overclocking
January 11, 2014 10:29:46 AM
It will fit perfectly :D .By the way,which processor and motherboard you gonna use ? So I will tell that if it is compatible with your CPU and Motherboard or not! What's your budget for cooling systems?
