Sign-in / Sign-up
Gtx 770 three way sli vs Gtx 780 sli vs Hd 7990 quad crossfireX, all water-cooled for triple monitor setup
  • SLI
  • Graphics
  • Gtx
  • Quad
  • Monitors
  • HD
Last response: in Displays
September 2, 2013 8:24:53 AM
Hey everyone, I'm building a water-cooled computer and I'm wondering if i should choose Gtx 770 three way sli or Gtx 780 sli or Hd 7990 quad crossfireX, all water-cooled for a triple monitor setup. I'm also wondering if AMD has fixed their frame latency thing with their new driver. Thanx
More about : gtx 770 sli gtx 780 sli 7990 quad crossfirex water cooled triple monitor setup
a b C Monitor
September 2, 2013 8:30:52 AM
AMD didn't fix crossfire yet. 3 way SLI doesn't work that well either. So GTX 780 SLI for sure.
m
l
a b C Monitor
September 2, 2013 9:25:13 AM
Theodor Maurstad said:
are you sure? http://www.tomshardware.co.uk/AMD-Catalyst-13.8-beta-mi...
780 SLI would be your best option out of the 3. A 3rd card gives less price per performance gains, add the cost of WCing and does not make scene, maybe wait a couple months and get the new 790.
m
l
September 4, 2013 3:18:06 PM
gtx 780 sli
btw I wish I had that kind of money
m
l
September 4, 2013 3:25:59 PM
GTX780 Sli all the way.. for less bucks than titans + it beats the titans for less $$$.
m
l
