Hi,
I am really interested in water cooling however, I am unsure of which parts are compatible, specially the tubes and the fittings. I plan on getting the upcoming Phanteks Enthoo Primo case which I find is the best low cost water cooling case there is.
I plan on having dual quad 120mm rads.
Here are the parts I could gather that I think would be good. It's the best I can do.
http://img407.imageshack.us/img407/8577/fuol.png
Any suggestions on what parts I should change? How could I make this cheaper while maintaining the dual quad rads? I want to use compression fittings also because it just looks better.
Is the pump good enough? Are the tubes and fittings compatible?
