Hello guys,
I would like to ask few questions regarding water cooling.
My specs:
Proc: i7 4770k
Mobo: asrock Z87M Pro4
GPU: Gtx 780 eVGA SC
I was thinking of buying one of the water cooling kits that were suggested into the forum and I have read the sticky. For now i want to do only the CPU and maybe later I'll add the GPU. The goal is better OC potential and temps. My question is should I try to cool down my voltage regulators with some additional cooling? And if yes what would you suggest?
Also which one is better - kits vs buying the parts separately? What would you suggest? My budget is around 200-220$.
Thanks for reading!
My specs:
Proc: i7 4770k
Thanks for reading!
