Hello
I need a little help here with airflow , I got this coolermaster haf xm 922 case and I bought it with side panel window instead of the one with fan , now I wonder if I'd have any trouble if Im about to use 2way sli. The airflow path I plan to try is gonna be ( for intake ) 1x 200mm fan , ( for exhaust ) 1x 200mm fan top of the case and 140mm fan for rear. Also Im gonna use noctuna nh-d14. Do you guys think this airflow path would be good ? wouldnt something inside overheat? Also I wonder which way should I turn the noctuna fans , should it be vertical from top to bottom or horizontal from left to right? Does anyone similar setup?
