It will either be a WPS button (Wi-Fi Protected setup) - used for adding devices wirelessly which are WPS compatible, or a wireless on/off button.
Why don't you press it and see if you can see your wireless network on your computer after you press it?
If it is a WPS button, then you will need to log into the router's management page via a web browser and look for the wireless enable/disable setting
