Hello all! I'm very new to the world of water-cooling and I am curious if you all could look over my parts list to make sure that I'm not missing anything! I just want to really make sure that i'm not missing anything important, and that i have enough barbs and compression fittings (I am not even positive as to what compression fittings are for). Any help, tips, or info would be greatly appreciated!
Radiator:
XSPC EX240 2 x 120mm, Dual 120mm Low Profile Split Fin Copper Radiator -
Pump:
Swiftech MCP655-B Liquid cooling system pump
Resevoir
XSPC Acrylic Tank Reservoir for Laing DDC
CPU:
XSPC Raystorm CPU Block for Intel Socket LGA 1156, 1155, 1366, and 2011
Barbs:
XSPC 1/2" Black Chrome Barb Fitting with G1/4" Threads (10 barbs)
Hose:
Thermaltake V-tubler 200cm Flexible Viper Green Water Tube for Water Cooling Systems
Compression Fittings (not sure how these are used?
XSPC 1/2" x 3/4" Compression Fittings with G1/4" Threads (Black Chrome Finish)
Thank you!
Radiator:
Pump:
Resevoir
CPU:
Barbs:
Hose:
Thank you!
