Hi all,
My Diablotek case has 4 120mm fans. They all connect using only molex connectors, so there is no fan control.
My system board has a 4 pin header to control the fans, but I cannot connect my fans to the system board.
I could get this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005
Or
I was thinking of getting something like this:
http://www.microcenter.com/product/341752/Akasa_PWM_3-way_Splitter_-_Smart_Fan_Cable
Which way would you go?
Any help is appreciated.
Thanks,
Or
Thanks,
