Hello all,
I am building my first water cooling pc and could use some help picking out the components.
What I'm cooling
Intel i5 2500k cpu - socket 1155
2 Nvidia EVGA GeForce GTX 670 - SLI
I have the basic fundamentals down but I don't know exactly which parts I need specifically.
I'm going the route of external cooling just to be on the safe side that I buy a bunch of stuff and it doesn't fit inside.
What I need:
1 CPU Water Block & Accessories
2 GPU Water Blocks & Accessories
Radiator - Quad Fan
Pump
Reservoir
Tubing and Fittings - 1/2in and/or 3/8in
Coolant - with anti-corrosive and anti-conductive properties
Thermal Paste
I believe that's all I need.
Your input would be much appreciated.
What I'm cooling
What I need:
Radiator - Quad Fan
Pump
Reservoir
Thermal Paste
