makkem Distinguished Jan 22, 2012 1,962 5 20,965 Sep 12, 2013 #2 HI Have you checked the fuse below the power input socket.
M mohamad ideal Honorable Sep 11, 2013 3 0 10,510 Sep 12, 2013 #3 mohamad ideal : Why my mixer wont turn on makkem : HI Have you checked the fuse below the power input socket. Hey thank for the reply. Ive saw the fuse below the socket . What shud do with it
makkem Distinguished Jan 22, 2012 1,962 5 20,965 Sep 13, 2013 #4 Its basically a little drawer,open it with a screwdriver and remove the glass fuse. Ideally check the fuse with a continuity meter,but if not available you may be able to see the fuse wire and check that it is continuous from side to side.
