Please make sure these parts are compatible
pugsofwrath
32
This is my first build and I don't want to screw anything up. This will be for moderate gaming computer and if there are any changes you wish make, know that I have a price limit of about $730. Here are the links.
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Graphics card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125453
If I missed anything, just say so. Thanks!
RazerZ
Judicious
Ambassador
Nice try for your first build, but get this since it saves money and has better performance:
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($117.98 @ Outlet PC)
Motherboard: ASRock 970 PRO3 R2.0 ATX AM3+ Motherboard ($81.98 @ SuperBiiz)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-2400 Memory ($63.04 @ NCIX US)
Video Card: PowerColor Radeon HD 7770 GHz Edition 1GB Video Card ($69.99 @ Newegg)
Total: $332.99
(Generated by PCPartPicker 2013-09-12 17:03 EDT-0400)
Also you are missing a lot of things... case, PSU, optical drive, Windows OS
RazerZ
Judicious
Ambassador
Here's a quality build which is a lot better for gaming than your current build. It's also really quiet too.
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard ($79.98 @ Outlet PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Outlet PC)
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($199.99 @ Newegg)
Case: Corsair 330R ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($44.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ Outlet PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $742.91
(Generated by PCPartPicker 2013-09-12 19:20 EDT-0400)
pugsofwrath
32
My reasoning for Windows 8 was that if more game makers begin to make games for Windows 8, I would not have to upgrade in the future.
RazerZ
Judicious
Ambassador
Lol yep, they are the top site for pc parts. Also I strongly suggest to get windows 7 because windows 8 is just a copy of it with a really weird interface and no start menu. I would only get 8 if you were using a touchscreen monitor.
pugsofwrath
32
How do I do that? (I'm sorry, this is the first time I've done this)
RazerZ
Judicious
Ambassador
pugsofwrath
32
I think I can. Thank you for all the advice. I'll check back with you in about a week or 2 and tell you how it went. One last thing. How do I select a post as the solution?
RazerZ
Judicious
Ambassador
just look for my comment and there should be a button saying "pick as solution"
RazerZ
Judicious
Ambassador
RazerZ
Judicious
Ambassador
pugsofwrath
32
I will have to find a cheaper video card. I just can't squeeze into my budget.
I also can not find the button saying "pick as solution"
RazerZ
Judicious
Ambassador
Well it's ok but for $40 more highly suggest to get this card. The reason is because it will last you longer and has better gaming performance. It was officially recommended by BF4 to have a GPU of 3GB, hence the HD 7950 series. Plus you also get 3 free games with it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
