I was cleaning up my pc for dust and now my monitor says there's no hdmi detected no matter what monitor I try. It also doesn'
  • Monitors
  • HDMI
  • Graphics
September 16, 2013 7:17:34 AM
I feel so lost. I was cleaning my pc for dust with air prior to this happening. I did not remove my gpu except for wiping a dust smudge with my thumb, except I was sure to remove the static with my hand beforehand. Now my monitor is displaying no hdmi or VGA connection to any monitor I use. Please, help me.
More about : cleaning dust monitor hdmi detected matter monitor
September 16, 2013 7:37:52 AM
Are all cables connected properly ? Happened to me once and it was because a cable slipped from the monitor.
Anonymous
September 16, 2013 7:40:20 AM
try to connect cable on motherboard vga or hdmi socket. then connect again to your GPU socket while your pc is ON
September 16, 2013 7:52:51 AM
I've done this before on a old £40 PC I was learning how they worked, I just Poked a little Black bit on the GPU and it fried the hole thing.
I'm not saying this happened to you, but it is a possibility.
September 16, 2013 7:53:35 AM
They're all in 100%
September 16, 2013 9:38:17 AM
Freaking Derp. I had it into the mobo socket the whole time. I plugged it into the GPU socket and it's up and running. Thanks.
