So, yesterday I replaced my old athlon x2 64 with a faster phenom x4 965. I removed the old thermal paste using some rubbing alcohol, 91%. I got it out with no bent pins, and put in my new phenom. I reapplied the thermal paste using the dot method to let the heat sink do the spreading. I put the heat sink back on and secured it with the latches. I went to go plug my computer back in. i got everything plugged in, and started it. It seemed to startup fine, all the lights and fans were on, but my monitor wasn't detecting any VGA input. I know it wasn't my VGA because i tried two different ones. This may also be a PSU issue. My specs are: 9500gt GPU, phenom x4 965, 8gb ddr2 ram, and an ATX 20/24, which i think has 480 watts, not sure. this only started happening after i put in my new CPU.
