I had a terrible day yesterday and decided to do some maintenance using water and I payed the price. I'm trying to narrow down the issue to try to limit what I replace. I don't have replacement parts to swap out for testing purposes anymore.
The system runs as long as the CPU's EATX12v is not supplied power by the 4+4 from my PSU. The 4+4 connectors all read 12v when checked with a multimeter.
With the 4+4's connected the unit power cycles - up for a second, then down, then up, then down - and the CPU_LED light is on.
1) Is there a way I can check or identify if its the connection on the motherboard that's bad? I'm guessing not, unless I'm familiar with electronics/soldering/etc., right?
2) If the 4+4 and the 20/24 and molex connectors from the PSU all read the right voltages it's a safe bet that the PSU is fine and I'm looking at replacing MOBO/CPU, correct?
3) My MOBO is a LGA 1156 - discontinued, and from my quick reading 1156 processors are not compatible with LGA 1155 boards - so even if the CPU is somehow good but the board connections have a short from water damage, I have to replace both.
I'm in a weird spot where I have to assume both CPU and MOBO are bad. If I buy another 1156 (discontinued) board and drop the CPU in and the CPU is bad, then I have to try to buy another (discontinued) processor...
But, it would be nice to assume just the MOBO needs replacing...
Suggestions?
Suggestions?
