Sign-in / Sign-up
Solved
Problem with current monitor. Should I buy new or fix?
  • Peripherals
  • LG
  • Monitors
  • Power
Last response: in Displays
September 20, 2013 2:30:41 PM
Hi guys,
My LG Flatron L227WTG has stopped working. The screen is black and the power button blinks very deem, to a point where you can barely see it, and doesn't turn on. From what I read, it seems like I need to replace the capacitors- but because this is something I don't know how to do myself I will be taking it to a shop-if I decide to fix.
What I wanted to ask is: being a 6yr old monitor, is it worth fixing it and how much should I expect to pay? If it is a better idea to buy new, what is the cheapest (due to being at a tight budget) monitor that I can get, yet that will have better specs/picture quality than my LG? I use it heavily for gaming and video viewing, and I have been very happy with my monitor (and its 2ms response).
Should I buy new (which one?) or is it worth repairing? Thanks in advance
More about : problem current monitor buy fix
Best solution
a b C Monitor
September 20, 2013 2:40:50 PM
With today's prices, $150-$200 will get you a lot of monitor. Here is a 23" LG:
Repair shops typically charge $60-75 per hour on repairs, minimum of 1 hour - so you are looking at 50% of the cost of the monitor to repair it. Given that it is 6 years old....go with a new one.
a b C Monitor
September 20, 2013 2:51:01 PM
I've replaced parts in an LCD monitor before (Westinghouse brand, can't remember the model number), and I'll tell you this: The scariest part of it was plugging it back in after I was finished working with it. I wasn't sure if it would turn on or turn to flambe!
It would probably be easier to replace the monitor instead of fixing it. A new one would probably have a better screen resolution.
Casey
m
l
a b C Monitor
September 20, 2013 7:48:38 PM
Agree it would be better to just replace the monitor.
m
l
