4 pin 12v atx socket vs 8 pin atx power plug.
  • ATX
  • Power Supplies
  • Socket
  • Components
  • Power
Last response: in Components
September 20, 2013 4:37:21 PM
Hi all
I've just purchased a Corsair CW430 PSU to go with a Gigabyte H61M-USB3H (micro ATX).
For the CPU power the mboard has a 4 pin socket but the power supply has an 8 ping plug.
Can I use the 8 pin plug (first 4 pins)?
Can I buy an adaptor?
Should I return the PSU.
Any advice greatly appreciated.
Charlie101
More about : pin 12v atx socket pin atx power plug
a c 152 ) Power supply
September 20, 2013 4:39:56 PM
The plug should split up if you pull it apart into 2 4-pins, usually.
September 20, 2013 4:47:01 PM
Hi jimthenagual
Thanks for your reply.
The plug is one piece plastic so it wont spit cleanly but it does plug into the socket with 4 pings over hanging. The wiring looks like it is effectively two plugs. But I know nothing about electronics so I thought I'd better check.
From what you're saying it is effectively two plugs so I should be able to use it as is.
Just let the unused pins hang in mid air?
Charlie101
So that's what I did and it seem to be working fine.
a b ) Power supply
September 21, 2013 2:09:50 AM
Its a 4+4 pin so it should split apart like jim said.
Normally they slide up to seperate.
Only one side should fit into your 4 pin.
