Sign-in / Sign-up
Solved
Corsair Enthusiast Series TX850 - 80 Plus Certified Power Supply
  • Western Digital
  • Power Supplies
  • Corsair
  • Components
  • CPUs
Last response: in Components
September 23, 2013 8:12:03 AM
Biulding up my new Rig With The Following specs
Asus Maximus VI Hero
i5 4670K
8 Gb 1866 Mhz
2 TB WD GREEN
64 Gb Neutron Series
I want to know that the following psu will be enough for my rig planning to buy 2 X GTX 760's
the product details are as follows this not a v2 version of tx 850 in my Country Pakistan
http://www.corsair.com/tx850w.html
Also Prefer Me A PSU From THE Following Website because i want to buy PSU Locally From Pakistan..
http://www.czone.com.pk/power-supply-pakistan-ppt.183.a...
http://www.galaxy.com.pk/power-supply-pakistan.html
http://www.iamextreme.net/category.php?CategoryId=5&Sub...
More about : corsair enthusiast series tx850 certified power supply
a c 408 ) Power supply
a c 1105 à CPUs
September 23, 2013 7:24:13 PM
That's a great PSU for dual GTX 760s. But I would look at a regular HDD, rather than the green drive. They tend to slow down when not in use. And they are not intended for a boot drive use.
From WD:
"Recommended use.
WD Green hard drives are tested and recommended for use in PCs as secondary storage, external enclosures and other applications that require cool and quiet operation."
m
l
a c 5558 ) Power supply
a c 2485 à CPUs
September 23, 2013 9:15:15 PM
It's more than enough , a good 750w would run those specs.
m
l
September 23, 2013 11:26:22 PM
WD GREEN cost me around 105 $ in my country and WD black cost me round 180 $ in my country
m
l
a c 2485 à CPUs
September 24, 2013 5:56:44 AM
WD Blue?
m
l
a c 1105 à CPUs
September 24, 2013 11:40:15 AM
Yeah, the Blue is the normal one purchased for general use.
m
l
September 24, 2013 12:08:28 PM
i usually play games and graphics
m
l
a c 1105 à CPUs
September 24, 2013 12:15:02 PM
That's what I meant. How is the price of the WD Blue drives where you live?
m
l
September 24, 2013 9:04:04 PM
WD blue not available in my country stores only red.black.and green is available . I live in middle east country Pakistan
m
l
September 24, 2013 9:05:27 PM
SR-71 Blackbird said:
WD Blue?
not available in my country...........
m
l
a c 1105 à CPUs
September 24, 2013 9:21:47 PM
OK. Point taken. Just be aware that the green drive may spin down occasionally. Or run at a slower RPM. And may not last as long.
m
l
September 24, 2013 11:37:55 PM
can you suggest me cpu cooler between these?
Thermaltake Frio Advanced 58$
Thermaltake Jing 61$
i will use a z87 mobo with a core i5
m
l
a c 2485 à CPUs
September 25, 2013 6:24:19 AM
Thermaltake Frio
m
l
a c 1105 à CPUs
September 25, 2013 10:22:47 AM
+1^
Agreed. The Frio has a better heat pipe contact with the CPU because of its direct contact design. It also has a bigger fan(s).
m
l
September 26, 2013 12:45:01 AM
clutchc said:
+1^
Sir will GS 800 is equivalent to the TX 850 in perfomance
m
l
September 26, 2013 1:05:48 AM
Thermaltake Frio
getting it for 110$
instead of 130$
m
l
Best solution
a c 2485 à CPUs
September 26, 2013 10:24:55 AM
The GS 2013 MODEL is a better unit.
September 26, 2013 9:53:33 PM
Yeah I am buying a 2013 but how do I know that it is 2013 model or older ?
m
l
November 12, 2013 11:31:09 PM
Bought the GS 800 PSU
m
l
a c 2485 à CPUs
November 13, 2013 4:49:11 AM
Good choice.
m
l
