Hello,
I'm wanting to set up a water cooling loop in my Antec 1200, I play a lot of games, overclock a little and want my PC to be able to hand most things.
My Rig at the moment:
Case: Antec 1200
Mobo: Asus P8Z68 V-Pro
CPU: 2500k @~4.5Ghz
GPU: Palit 660Ti Jetstream (Default OC)
PSU: 650W
RAM: 8Gb G-Skill Ripjaws
The water cooling components I've got together (including new GPU) are:
http://www.scan.co.uk/products/ek-coolstream-rad-xt-%28240%29-radiator (x2)
http://www.scan.co.uk/products/33m-%2810ft%29-masterkleer-1-2-id-3-4-od-hose-dark-green-uv-boxed
http://www.scan.co.uk/products/4gb-evga-gtx-770-class-hydro-c-28nm-pcie-30-7010mhz-gddr5-gpu-1165mhz-boost-1215mhz-cores-1536-dport
http://www.scan.co.uk/products/ek-ekoolant-uv-lime-green-premix-1000ml-includes-additives-against-algae-and-corrosion
http://www.scan.co.uk/products/120mm-akasa-apache-black-ultra-silent-fan-hdb-bearing-pwm-fan-w-4-pin-connector-and-rubber-pins-reta (x4)
http://www.scan.co.uk/products/xspc-acrylic-dual-525-reservoir-for-laing-d5
http://www.scan.co.uk/products/alphacool-laing-vpp655-d5-pump-t12-%281-2-barbed-connectors%29
http://www.scan.co.uk/products/bitspower-bp-mbcpf-cc5-g1-4-matt-black-compression-fitting-cc5-for-id-1-2-od3-4-tube (x?)
http://www.scan.co.uk/products/ek-supremacy-elite-intel-115x-cpu-water-block
So I'd like to know if this would work (effectively) or if you'd suggest and improvements for a similar price range. The rads would be one in the front and one at the back with 2 fans on each and I'm not sure about hose fittings so would appreciate some advice with those.
Thanks,
Dave.
Case: Antec 1200
CPU: 2500k @~4.5Ghz
PSU: 650W
Thanks,
Dave.
