Hey people,
I've recently upgraded some components of my PC but the wife says I can either buy a new high res monitor or a new case so I'm going with the monitor.
I've recently bought the XSPC RayStorm 750 RS360 kit. Thing is I have the rad mounted in a very, very bad place at the bottom of my case where I can only put 2 fans on it:
Needless to say it is not cooling as efficiently as it should. What I want to do now is add watercooling for my GTX 770 oc Windforce 4GB. Question: Does anyone know if this will fit http://www.xs-pc.com/waterblocks-gpu/razor-gtx-770 and if it doesn't what will?
Also, should I run a single or a double loop? From what I've read, the pump I have is average at best, if I run a single loop would I need to add another pump?
Now my biggest question is, where the heck should I mount the rads? I'm more than willing to drill/cut holes. I want to get another 360mm rad for the GPU. I was thinking about mounting them on the right hand side of my case? Pic for reference:
I've searched everywhere for pics of the Armor series with side mount rads and I can't find anything. All I can find is rear or top mounted one's. Rear would get in the way and I don't like the look of top mounted... Is there any negative aspects to side mount?
Thanks in advance. It's great to have a community of enthusiasts at hand to bounce ideas off.
