Hi All
Trying to setup eyefinity with 3 HP LP2465 monitors and an xfx 6870.
I've just received my mini dp to dvi active adapter and thought it would be easy.
Prior to the adapter arriving I already had 2 of the monitors working as an eyefinity group no problem. via the 2 dvi ports.
I've connected the third monitor via the mini dp port and adapter and eyeinfinity knows it is there but no matter what i try i can only get any 2 monitors to turn on at any one time
The lp2465's have 2x dvi ports which can be digital or analog.
I'm using 2 way digital dvi cables from the monitors to the cards dvi ports and another digital dvi 2 way cable from the 3rd monitor to the active mini dp adapter.
Like I said i can get any pair of monitors to work together but cant seem to enable the third.
OS is win 7 ultimate 64bit and the ccc and driver is 13.10beta
Any help appreciated
Stu
Stu
