When I insert my USB stick into my USB Drive, it won't read it, PLEASE help!
  • USB Stick
  • USB
  • USB Drive
  • Disk Read Error
  • Windows 7
  • Flash Media
Last response: in Storage
September 28, 2013 10:29:58 AM
Dear all,
When I insert my USB into the USB slot, it simply won't read it. When I click my computer, the disk is greyed out, and when I right click and format it, it says there is no disk inserted WHEN IT CLEARLY is...Please help someone!
BTW I don't know where else to post this so I selected Windows 7, as im using windows 7.
More about : insert usb stick usb drive read
September 28, 2013 3:31:34 PM
Did you build the PC yourself? If so make sure the USB header is attached. If not check online for drivers for the USB. Finally use a different port and if that doesn't work use a different USB stick.
February 20, 2014 5:01:10 PM
Have you tried the usb drive in another computer?
February 21, 2014 2:08:01 AM
Actually there was a problem with the USB stick itself. So I got rid of it and got a new one. Thanks for replying tho.
