I've got my first build almost lined up and ready to purchase, currently I'm going through each product and making certain it's what I want and will fit with the relevant parts.
Currently I'm looking at this: http://pcpartpicker.com/p/1J5Y0
The case comes with 4 fans, 7 total fan slots. I picked out 3 more 200mm x2 and 140mm, because you can't have too many fans right?
Long story short the reviews mentioning using a 200mm for the side say that a Hyper 212 will not fit.
But the specs of the case say max heatsink size is 150mm/180mm(side fan on / off)
Yet the H212 is 80mm tall, and the NH-D14 is 140mm tall.
...? According to the specs both should fit with a side mounted 200mm, unless I'm reading something wrong? Help please!
This is the Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
This is the NH-D14
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
And the Hyper 212
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
This is the Case
This is the NH-D14
And the Hyper 212
