Thank you for the suggestion, but are you sure that this will work when tilted on its side? I know that heatpipes use some liquid inside them which pools at the bottom and is then evaporated by the CPU, and goes to the top and condenses, but unless this one has wicks in the pipes, it probably won't work if tilted on its side, am I right?
