Yes of course, you just plug the 3 pin fan connector on the first 3 pins you can tell the first 3 pins because it has that extra "guider" peice of plastic on top. Then the 4th pin just sits on the side. I know this because all i have is 4 pin connectors on my motherboard(sabertooth 990FX) and thats how my fans are connected.
