A question about power supply, and if I would need more power.
Bobby_514
Hello, I have just ordered my gaming computer ( http://www.newegg.ca/Product/Product.aspx?Item=N82E16883229420 ) and this model comes with a 800W Power Supply. Now if I wanted to upgrade the graphics card to lets say 2-way sli gtx 670's instead of just the one that comes with it, would I need to also up the supply? or is 800W sufficient?
answer
Last reply
More about question power supply power
The 800 watts PSU will be adequate if it is a good quality PSU; Corsair, Antec, XFX, Seasonic, or equal.
The GTX 670 draws 170 watts and requires a PSU which has a minimum of 30 A on the 12V rail - http://www.evga.com/Products/Product.aspx?pn=04G-P4-3671-KR
Gaming
Power Supplies
Computers
Graphics Cards
Power
Related Resources
- solved Question about a new power supply, I need to know if it this will work for me.
- What size power supply should I need?Also some more newbish questions.
- solved Question about Q6600 and it power supply
- solved Quick question about a GTX 1060 with a CX430 power supply
- solved Question about my power supply.
- solved hi,i have a question about power supply and case compatability
- solved i need advice about getting the best 850W power supply for my computer
- solved Will my power supply suffice and do i need more fans?
- solved Do i need more than 750 power supply?
- solved Question about Power supply
- solved Does my cpu need more power or is my power supply broken?
- solved Question about power supply for system build
- solved Can I overclock it? and also do I need more power supply?
- solved Will I need more cooling/better power supply to overclock my cpu/gpu?
- solved Question about a certain power supply
- Power Supply Cables? Need more.. Can I use any?
- solved Upgrading HD7870 to GTX 690? + Side question about power supply
- solved Question about Power supply and case :)
- solved Power supply and mobo question about gpu upgrade
- solved Do i need more power supply? Help appreciated:)
