Two year old DV6 stopped working entirely, no lights, no beeping, no power. The laptop wouldn't turn on, I did a hard reset by pressing power button for a few minutes and it didn't work. I tested my power supply cord with a multimeter, got about 9 Volts and then I proceeded to take apart the laptop to inspect the Motherboard.
I suspected the entire motherboard to be defective however when I took the laptop apart, only leaving the motherboard in tact I plugged in the power supply cord and I got a light on the power jack indicating the computer was receiving power. I then turned it on and the laptop worked. however after connecting the hard-drive and putting the computer back together it stopped working again.
Every time I take apart the laptop it works fine but when put back together I get no power.
My question is if it where a bad power jack would a fully charged battery be able to turn on the computer? I have used a fully charged battery but it didn't work.
Thank You
Thank You
