Hi guys, I'm having problems with my PSU constantly blowing! I've blown 3 in the past 5-6 months now and worried I've got a serious hardware problem.
I built the system end of last year for gaming.
Main components;
AMD FX-8350
1GB MSI HD7850 R7850-1GD5(Over clocked version)
GByte GA-990XA-UD3 Mainboard
2x 4GB Corsair DDR3 1866 MHz
Alpine 700W Blue PSU - 12cm Fan
I know the PSU is a cheap one and I've blown two of these, but the third oen I blew wasa bit better quality and more expensive. Im relucant to get another for it to just blow in a couple of weeks!
Now I do think the issue is heat/load related as it seems to blow when gaming and/or when the room temperature is high. I am running the stock cooler that came withthe processor, whioch I also know needs replacing witha better cooler as the 8350 is running as hot as the sun!
Anyway, Im just wondering , cooler/ventilation aside, is there anyhting else I am missing that could be causing this problem? Is the card drawing too much power for instance? Maybe the PSU being 700w is far too big? I don';t know I just want to get this fixed before I spend more money on the solution. Cheers
Main components;
AMD FX-8350
