System upgrade: old PSU only has 4 and 6pin but new MB has 8pin?
Last response: in Components
- Can I run the GTX 460 768mb on a 6pin + 8pin 500W PSU. - Forum
- I want to get a Asus GTX760 DirectCU II OC but it requires a 8-pin and I only have 6-pins and 4-pins - Forum
- My new Mobo has 8-pin EATX12 V cpu plug but my PSU only has the 4pin? - Forum
- 8pin PCI-e powered cards and old power suplys with only 2 6-pins, any solution? - Forum
- Only got 4pin on my psu but 8pin on my motherboard. - Forum
- SolvedOld PSU with 4-pin on a AM3+ 8-pin motheboard Forum
- SolvedUpgrade to a silent setup or buy/build a new one... 4-year old system Forum
- Solved4 year old PSU in new system? Forum
- Solved200 euros upgrade for new cpu and MB only Forum
- SolvedHelp please, new system crashed only 1 month old Forum
- SolvedSeeking Graphics Card Upgrade Advice for 4 Year Old System Forum
- Solved6 year old corsair PSU in new system Forum
- Solvedshould i buy a new pc or upgrade my old system? urgent help needed? Forum
- SolvedDo I need to upgrade my 4 year old PSU for haswell build? Forum
- Solvedmy friend is doing a rebuild with new mb and cpu can he use his old os that was upgraded Forum
- SolvedNew system or try to upgrade old system? Forum
- SolvedVideo card upgrade old system i7 first generation ok or shell out tons of $ build new system. Forum
- SolvedNew build with old HDD only tries to do system restore Forum
- Lifetime of a 6 year old E5200, 4GB RAM, 9500 GT 1GB DDR2, 750 GB HDD, 2 Fans, 300 Watt PSU system Forum
- old psu for new system? can it handle it? Forum
- More resources
Read discussions in other Components categories
