Your home theater seems to only have 1 analog audio input. Your TV probably only has an optical audio output. Your options are to use an digital to analog converter or connect the analog audio out of the laptop to the HTiB directly. If you have other sources such as bluray or cable connected to the TV then you would have to use the DAC.
