Hey there Tom's!
I've come to a head of sorts. I have a few decisions to make.
The first is what to do with my beloved PC. I have, unfortunately, gotten bit by the audiophile bug. What that means is that my stereo system will soon have its own dedicated (silent) (hopefully mini-itx) rig, using my sound card and a Pentium D. (I kid, I kid, it's a G2120.)
I haven't decided yet what I want to do with that rig, cooling wise.
At the same time, my computer as it is will be moving into a CaseLabs S5, mostly for the versatility that mATX gives you. I absolutely love the mini-ITX form factor, but boy is that extra expansion slot calling out to me. It will still contain an i5-3570k, with custom watercooling. The reason I want to split the rig into two is mostly due to sound - watercooling is a hell of a lot noisier than I imagined going into this.
So here's my question. Since the media PC won't have to be mobile like my gaming rig does, should I take a page from the kids in Brazil and mount it externally on tacboard? The benefit to this is that it allows me to use piping with custom copper fins to create an absolutely silent watercooling rig - it would be powered by the heat of the processor, causing the hot water to rise and the cooler water to fall. (I've seen this done somewhere, I just don't remember where. However, I'm confident I could make it work.)
The other option is, as I'm turning my rig into a heftier (but not so much larger - the prodigy is a sizable beastie) computer, do I give it an external radbox? This would, I think, be somewhat simple to achieve - my reservoir is mounted externally, with two extra ports. These could be used to connect to quick-disconnects leading to the radbox, which would have its own pump. The idea would be to have two separate loops, so that I could disconnect the radbox, turn off the overclock on my CPU, and use two 2x120 radiators to cool a stock i5 and one or two high-end graphics cards.
So what do you all think? The radbox would be a fair bit more expensive, but not too much - copper is freaking expensive, and there would be a few plumbing tools I'd have to go buy that I don't currently have.
Which would be more fun? Which would give me cooler bragging rights?
I kind of like the modular idea of a radbox, but then again, having a computer mounted on a plate on the wall with this giant copper thing coming out of it does sound kinda fun...
