The Pc Build Is This
http://www.microcenter.com/product/418037/AM3470-UR12_Desktop_Computer
My Problem
I want a graphics card that is better than the integrated one that I have. I dont want it expensive. Ones that I did see that were good needed power supplies 400w but not sure if its compatible with the pc or not.
So I want to get the best cheapest compatible graphics card
I want a power supply under 450w that is compatible with everything in the build
So basically I want everything to be compatible, and I dont want a huge power supply.
Id like to get a reply asap.
NOTE: That I play Minecraft, CubeWorld, Skyrim(I want to get this game), Pokemon 3d,Team Fortress Two.
NOTE: That I record gameplays aswell.
My Problem
