I just bought a 7870 for my rig, my psu has 1x6 pin power for the gpu, but i need another 6 pin. It came with a 6pin to molex
- SolvedCan I Convert Two 4pin Molex Connectors to 6pin PCIe to power AMD HD7870 Forum
- SolvedPsu advice needed - 6pin power draw check Forum
- GPU needs two 6pin power plugs, can i use two on the same cord? Forum
- do I need to plug ATX 6-pin power connector from PSU to MB? Forum
- Recom PSU needs 2 x 6pin PCI power adapter Forum
- More resources
