Older xbox 360 with no connection to ethernet cable, and can not join a wifi. please help if u have an idea
  • Ethernet Card
  • Xbox 360
  • Networking
  • Connection
  • Cable
Last response: in Networking
October 19, 2013 3:00:47 PM
I have an older xbox 360 and the ether net port on the back will not read if there is an ether net cable plugged into it. and
More about : older xbox 360 connection ethernet cable join wifi idea
October 20, 2013 6:19:48 AM
Your best bet is to see if you can buy a cheap refurbished one at this point and replace it, MS wants $100 to repair it. you might find a third party to do it cheaper, maybe even places like gamestop will help you, since they basically repair and refurbish them then resell them.
The other option is buy a wifi dongle and use that, it plugs into a USB port, but again costs about $100 every time I see them, though I have seen a few used in game stop for about $50, still not a worth while investment at this time as the 360 is soon to be replaced with the xbox one.
