Are any of my parts going to bottleneck or be bottlenecked by other parts? Is this a good build?
Last response: in Systems
- GPU Bottlenecked by other PC parts? - Forum
- General help on picking parts ( Bottleneck, and making good decisions.) - Forum
- Is this build bottlenecked? Please help, I'M BUYING PARTS NOW! :( - Forum
- would these parts make a good gaming pc and would they bottleneck? - Forum
- Is this a good set-up to build a gaming computer? Also, are all these parts compatible with each other? - Forum
- SolvedBest parts as far as fans go & CPU bottlenecking GPU? Forum
- Please suggest a good MOBO (and other parts) for my first build Forum
- SolvedI was going to build a pc and I was wondering if all of the parts were compatible. All of the components are i Forum
- SolvedWill my PC bottleneck any parts? Forum
- SolvedAre these parts a good choice and are they compatible with each other? Forum
- SolvedAre these parts going to be compatible and be able to play ultra/high settings at a good framerate? Forum
- SolvedAre all the parts in this build compatible with each other and how will it peform when playing games? Forum
- SolvedIs my graphic card good enough and should other parts be changed out instead? Forum
- Solvedis contact cleaner good for cleaning heat sinks and other PC parts? Forum
- SolvedAre all these parts good with each other? Forum
- SolvedMy new Build. Need recommendation with other parts. Forum
- SolvedAre these 2 parts going to work together good? Forum
- SolvedWill these parts bottleneck (CPU and GPU) Forum
- SolvedDo these parts bottleneck together? and if so which part(s) is the bottlenecker? Forum
- SolvedHome Built Gaming PC, Going to upgrade it but want to use old parts to build budget PC for (11yr old son) Forum
- More resources
Great rig, I'd love to have it....should do about anything you want it to....on the DRAM for a 2x8GB 2400 might look at the GSkill Tridents, they are stronger sticks than the Corsairs, Have in both my IB and my Haswell (see sig)
