Solved
Are these parts all compatible with each other? anything wrong that i should change
  • sshd
  • RAM
  • Tom's Hardware
  • CPUs
  • Motherboards
  • GPUs
  • Compatibility
Last response: in Forum Feedback
November 3, 2013 3:23:49 PM
CPU: AMD FX-6300 3.5GHz 6-Core Processor
Motherboard: ASRock 990FX Extreme3 ATX AM3+/AM3 Motherboard
Memory: Corsair Vengeance 8GB (2 4GB) DDR3-1600 Memory
Storage: Seagate 1TB 3.5" 7200RPM Hybrid Internal Hard Drive
Video Card: Gigabyte Radean R9 270X 2GB
Case: NZXT Guardian 921 RB ATX Mid Tower Case
Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply
More about : parts compatible wrong change
Best solution
a c 621 à CPUs
a c 1798 V Motherboard
November 3, 2013 4:41:26 PM
Looks good - assume you have an OS? and if planning to OC may want a good CPU cooler, the Hyper 212 EVO is very good with AMD CPUs and reasonable at about $30-35
November 3, 2013 5:12:43 PM
okay thank you thank you, is the power supply good
m
l
a c 621 à CPUs
November 3, 2013 5:22:31 PM
Yep, should be fine ;)
m
l
November 3, 2013 5:36:39 PM
ok thank you for the response
m
l
November 4, 2013 3:27:40 PM
is my case big enough will if fir the motherboard and the gpu wiht room to spare.
m
l
a c 621 à CPUs
November 4, 2013 3:51:17 PM
Yes should be good to go ;)
m
l
