I want to connect my xbox 360 by a hdmi to vga cable to my led monitor.But my monitor shows no signal check ur connection
  • Connection
  • Monitors
  • LED Monitor
Last response: in Opinions and Experiences
November 5, 2013 5:08:52 AM
Why is my my monitor not displaying the xbox window.
More about : connect xbox 360 hdmi vga cable led monitor monitor shows signal check connection
a b C Monitor
November 5, 2013 5:22:07 AM
You are trying to convert a DIGITAL HDMI to an analog VGA, this is not possible unless you have an ACTIVE CONVERTER.
m
l
November 5, 2013 5:51:36 AM
My cable consists of an hdmi end and a vga end that fits on the back of my
Led monitor
m
l
a b C Monitor
November 5, 2013 5:56:31 AM
Like I said, that will not work unless its an actual converter. If the monitor has an HDMI or DVI connector, use that instead.
m
l
