Power Supply under 100$ Modular
What Power Supply do you recommended?
  • Total voters
risklife
22
Hey guys, I'm putting together a pc, but I have a doubt in the power supply.
I need a power supply less than $ 100, because the shipping is expensive to Venezuela from USA.
I would like a modular 750W power, this is a very low budget.
What power do you recommend?
Thanks for all.
Sorry for the english.
Option: http://www.amazon.com/OCZ-Fatal1ty-Modular-Gaming-compatible/dp/B003JZCF2O/ref=sr_1_2?s=pc&ie=UTF8&qid=1383973159&sr=1-2&keywords=PSU+750W
Option: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182133
Option: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139051
Any other option best, for below price?
sheag123
619
seasonic components. very good psu
PCPartPicker part list: http://pcpartpicker.com/p/gCD
Price breakdown by merchant: http://pcpartpicker.com/p/gCD/by_merchant/
Benchmarks: http://pcpartpicker.com/p/gCD/benchmarks/
Power Supply: Antec High Current Gamer 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($94.48 @ Newegg)
Total: $94.48
(Generated by PCPartPicker 2013-11-09 05:10 EST-0500)
risklife
22
Well, i go to use a PO BOX(locker) for send to Venezuela, but if the product is more to 100$, I need pay nationalization.
Antec PSU OUT OF STOCK in newegg.
risklife
22
Thanks Vic, now, What is best, OCZ: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341052&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
OR Corsair CX750M: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139051&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Vic 40
Ambassador
Of those two probably the ocz although haven't read particulary bad things about the corsair.
But i would rather choose from the ones i linked.Either the xfx which is great or the cooler master if you wanted to save the $10,With the last one being as expensive as those two in your last post.
Vic 40
Ambassador
About the rebate,
http://en.wikipedia.org/wiki/Rebate_(marketing)
click the first one under "Money".
From what i understand you will have to first pay the full amount and later on go for the rebate which should be a kind of check for the rebate amount.It seems not to really be what you want from what i can tell.
The corsair cx 750m is still under the $100 even without rebate.
this, SeaSonic is known for HQ PSUs.
risklife
22
For the rebail mail, i need first buy the PSU, and later use his code for others products? I`m from venezuela.
Vic 40
Ambassador
I already linked one like that ,
and at least at newegg the price matches the one on the pcpartpicker parts list while at ncix they somehow don't.
We,both foreigners,are trying to determine what the whole rebate thingy is about,maybe you can shed some light on that?
