Selling Custom Watercooling Parts. Big discount if you buy them all.
  • Water Cooling
  • Hot Deals
Last response: in Deals
November 9, 2013 7:15:05 PM
Hi Toms Hardware,
I have for sale a big lot of used water cooling parts. I tried my best to put the thing together in my rig, but in the end I was just not good enough at building a decent loop and have decided to just go with a closed loop solution rather than take the chance of leaks due to bad setup.
I have up for sale the following:
XSPC Raystorm AX360 Kit which included:
AX 360 Radiator (has some scratching on the outside)
Raystorm CPU Block
XSPC X20 750 Pump/Res Combo (Rev. 4)
6 XSPC Chrome G1/4 7/16 x 5/8 Barbs
Still Sealed Package of Clear XSPC 7/16 x 5/8 Tubing (6 feet I believe)
All the backplates and screws needed to mount everything
A small tubing of XSPC thermal paste
3 XSPC Xinrulian 1650 RPM fans (attached to radiator)
PSU starter block
Biocidal Drops
I also have:
6 XSPC Black Chrome G1/4 1/2 x 3/4 Compression Fittings (2 are still attached to small bit of tubing that you will need to pull off. Already ripped up my hand pulling the rest off so sorry that is up to you)
3 XSPC Xinrulian 1650 RPM fans (for push-pull setups, not attached to radiator and you will need to purchase more 6-32 screws to mount them)
An Extra Backplate that suits LGA 1150 better than the one that came with the kit
I also have some used already cut tubing that I can throw in if you'd like. It's the XSPC high flex black tubing and there is the right size tubing for both the barbs and compression fittings.
I am looking to get 150$ for all of this stuff but may part out the bigger items. Shipping only to the continental US. We will discuss shipping price via PM. Items are sold as is. They are 100% functional, but it is your responsibility to put the parts together correctly and I can not be held responsible for any damage caused by improper setup or part failures down the line.
Pictures (sorry there is a glare on one of them for the page with my username and stuff on it, but the rest have that. It is still slightly visible though and I can fix that if mods require)
More about : selling custom watercooling parts big discount buy
November 11, 2013 2:21:29 PM
Taking offers on this stuff.
m
l
November 11, 2013 8:54:23 PM
Raystorm CPU Block (this will work with 1150 right?)
How much are you looking for them?
m
l
November 16, 2013 8:15:02 AM
I will take it all but Barbs, Clear tubing and Pump/Res
$90
m
l
December 7, 2013 3:31:25 PM
Im interested. How much for everything minus res? I have a few rads available to me already.
m
l
