I have a CM K380 Cabinet
1 Fan comes preinstalled in the front.The fan is installed in such a way that when i look from the inside of the cabinet i can see the CM Logo.So i think the fan is sucking air from outside.
My PSU has lots of wires which is in front of this fan and it obstructs the direct airflow
I have got 2 120mm Deepcool windblade fans.But now im confused in its installation.I intent to fix one fan at the back and one in side glass panel.But im confused with the orientation(which part of the fan blows and sucks air) and what is the air flow model you recommend.
