Sign-in / Sign-up
Solved
Just finished building my first gaming pc. Booted it up and no display on monitor.
  • Monitors
  • Power
  • Graphics
  • Displays
Last response: in Displays
November 22, 2013 6:05:16 PM
I hit the power button for the first time and the power light did come on, but nothing is on the monitor. Checked out the insides and the graphics card and heat sink fans are spinning. The LED on the motherboard is on, but no display...I'd appreciate any help! Thanks!
More about : finished building gaming booted display monitor
November 22, 2013 6:35:51 PM
jimthenagual said:
Here is a really good checklist to use. Some of them will seem obvious, but double check them anyways. Sorry to hear you're having troubles, and I hope they resolve soon!
http://www.tomshardware.com/forum/261145-31-perform-ste...
Hi thanks for responding! I did find that checklist and I discovered that I've made a pretty newbie mistake. I didn't plug anything into the socket next to the processor, the 8 pin one (number 2 on that list). I didn't get a cable that has 8 pins, all I have was the 6 pin pci-e cables I got with the power supply. Is there some way to make that work?
m
l
November 22, 2013 6:51:25 PM
Your PSU likely has at least one 4pin CPU connector, you can try with that plugged into the 4 pins closest to the CPU.
m
l
