I would like some advise on a system I am planning on building. This is my first build and honestly, it's my first real PC. My main concern is knowing my chosen parts will be compatible and that they will be good enough. (Again, expectations are not too high.) I've read through the stickies and will do my best to fill in all the information needed.
Budget: Let's call it a flexible budget.. $1000-1500?
Country: Western United States (Ordering all online.)
Overclocking: It seems like a good idea if it's planned now!
SLI or Crossfire: Input needed.
Resolution: I was planning to run a 32" LCD TV, I guess experimenting with res will ensue.
PC History: I've only ever owned cheap, low-end computers.
System Usage from Most to Least Important:
This will be a personal computer. No real "business" to be done. I know the PC will get a lot of use for gaming. I would like to be able to run the games at their highest settings. (Arma or Battlefield.) Aside from gaming I will use the PC for music (no real high demands there), movies, and photo/video editing. (Again, I could never get photoshop to even run in a timely manner.)
Here is the system I have put together. I want to note that I have VERY LITTLE knowledge of PC's and I have spent the night searching for most of these terms. (Most of my Google queries have returned me to this forum, which explains my choice to post here. A lot of my choices have been with budget in mind and in some cases- purely what has been recommended. Below are the parts listed with my reasoning.
(I used PCPartPicker.com to pick out the parts)
Click for link to the build if you want specs of parts.
CPU Intel Core i5-3570K 3.4GHz Quad-Core Processor
From what I have read this is the best bang for your buck for gaming.
CPU Cooler Corsair H50 57.0 CFM Liquid CPU Cooler
I own one already from a friends build, it says it's compatible with above CPU.
Motherboard Gigabyte GA-Z77X-UD5H ATX LGA1155 Motherboard
I picked it for the ram capacity but upon reading stickies I noticed the Intel Z77 chipset is a plus?
Memory G.Skill Ripjaws X Series 32GB (4 x 8GB) DDR3-1866 Memory
Cheapest set of 32gb to fit the above mobo. (Picked 32gb because of editing pic/vids.)
Storage Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Good for storing music, photos and games?
Video Card Sapphire Radeon R7 260X 2GB Video Card
Again it came down to the bang for the buck with gaming.
Sound Card Asus Xonar DS 24-bit 192 KHz Sound Card
I plan to plug into my surround sound occasionally. Seemed like good balance with quality/budget.
Power Supply EVGA SuperNOVA 750W 80+ Gold Certified Fully-Modular ATX Power Supply
"Estimated" usage is 363 watts. The rule is roughly double, correct?
Optical Drive Pioneer BDC-207DBK Blu-Ray Reader, DVD/CD Writer
Fairly cheap drive with a BR option.
Operating System Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
I have a personal preference to Windows 7, do not require much as far as OS options.
Case Apevia X-SNIPER2-BL ATX Mid Tower Case
The decision was roughly half looks and half available options. On top of the one fan that comes with the case I will be getting four cheap 120mm fans to help it out. However, I do not believe they will be needed. I would like advise on powering the extra fans. Can I hook them up to the PC and have them powered automatically at certain temperatures/loads or do I need a separate fan controller.
So there we have it. I personally think that it will all work splendid, but I don't trust myself too much with as little experience as I have! I think the most trouble the PC will ever have is running a game at full settings, opening photoshop or uploading a video. I am not opposed to overclocking it, but I have no experience with it. I am perfectly content not doing anything in that area but let me know if tweaking the build would help in that category.
I would love to hear some feedback on it if at all possible. Constructive criticism is welcome. I'm fine with it being overbuilt. If some parts are lacking or incompatible, let me know. The budget is flexible, but I cringe thinking about spending too much. It sits right at $1300 how it's listed above.
Thank you for taking the time to read this and in advance for any comments you may have. If you have any questions about any of it, let me know.
