T tribal123 Honorable Dec 1, 2013 2 0 10,510 Dec 1, 2013 #1 I plan on getting a H320 CPU Liquid Cooling Kit for my CPU. i would like to know if it can be used as well to cool both SLI 780 videocards too ? i would like to watercool both gpu and cpu using pre built radiators, tyvm in advance for your answer.
corvetteguy1994 Distinguished Oct 5, 2012 537 1 19,115 Dec 1, 2013 #2 i would look into doing a custom loop with a separate pump and res.
T tribal123 Honorable Dec 1, 2013 2 0 10,510 Dec 1, 2013 #3 i dont wat to add pumps and reservoirs etc .
corvetteguy1994 Distinguished Oct 5, 2012 537 1 19,115 Dec 1, 2013 #4 tribal123 : i dont wat to add pumps and reservoirs etc . well then dont look to cool 2 780's and a cpu with that little pump.
manofchalk Glorious May 11, 2012 12,914 3 48,960 Dec 3, 2013 #5 You need more radiator space than a slim 360mm if you want to cool all that.
