I work in an above ground waste water treatment facility. Our office is on the front of our 1 acre lot which houses our Frontier Netgear 7550. We are trying to get wifi throughout our facility for networking purposes.
2x100000 gallon tanks, one which is always full, 2x10000 gallon tanks, one which is quadruple lined and always full, various small tanks ranging from 1000 gallons to 5000 gallons. I should also note that our plant is at least 6 different buildings connected by breezeways or open areas.
I'm not sure if any of that info is important, I have read that water sucks the wifi signals up.
We need a very cost effective way to extend our wifi range to the plant. Speed isnt an issue, reliability is. Our goal is to remote our office excel docs from our office pc(which is in the office with the router) onto a tablet(which will be moving all around the plant on our persons), hence eliminating tons and tons of paperwork and also giving us real time useful information on our biological systems.
There are 2 main buildings in our plant that really need a reliable signal. One is a metal building about 60'x80', 20'tall. This building also houses our labratory which is a closed off room inside of the metal building that is important to have wifi. Currently our lab has a really weak signal from our office modem.
The second building is a metal wrapped "barn" if you will, with a dimension of roughly 100'x50'x20'tall. This building houses a 6000 gallon rectangular water tank that is roughly 10 feet tall and 28 feet long. The building also uses our 2, 100000 gallon tanks as partial structure. Roughly a third of each tank is protruding into the "barn".
I can also add that our wifi range as is works all the way to the far reaches of our plant foot print outdoors with nothing in the way between said tablet and the router. As soon a I step into a building I either lose signal completely or it becomes so weak its worthless to use.
