Sign-in / Sign-up
My monitor says "Check signal cable" when my pc is shut down, but it works properly when on
  • Cable
  • Monitors
  • Shutdown
  • Graphics
Last response: in Displays
December 4, 2013 4:02:21 AM
Hello, i recently bought a new gpu and i had to buy an vga/dvi adapter as well and now when i shut down my pc on my monitor it says check signal cable but when i turn the pc on it works good
Should i even try to fix it?
More about : monitor check signal cable shut works properly
a b C Monitor
December 4, 2013 4:03:30 AM
That is not a problem. Its telling you that no signal is being recieved... because the computer is off...
m
l
December 4, 2013 4:16:55 AM
oh my goodness...............
m
l
