O oggy13 Honorable Dec 7, 2013 2 0 10,510 Dec 7, 2013 #1 The Computer is on but the HP 2311x monitor wont turn on I have a Gigaware Dual link DVI cable connected to it
Azrael47 Distinguished Jun 1, 2013 1,629 0 20,460 Dec 7, 2013 #2 Check that the monitor is on the correct source (i.e. D-Sub or DVI). Also try connecting the DVI cable into another port to see if that will work. Upvote 0 Downvote
O oggy13 Honorable Dec 7, 2013 2 0 10,510 Dec 7, 2013 #3 Azrael47 : Check that the monitor is on the correct source (i.e. D-Sub or DVI). Also try connecting the DVI cable into another port to see if that will work. How to know if it is on source if it wont turn on? Upvote 0 Downvote
Azrael47 Distinguished Jun 1, 2013 1,629 0 20,460 Dec 7, 2013 Solution #4 should be buttons to press at the side or bottom of your monitor. Upvote 0 Downvote Solution
